ScornedNexus
Hello,
I seriously need help.
I replaced the glass of my s3 and, I think I did a pretty darned good job. But I have a problem. My return and menu buttons don't respond to touch, they light up though.
I don't believe there is anything wrong with the ribbon. Does anyone know if the ribbon relays touch or is that the glass/digitizer. I was of the impression that the ribbon is simply a light transmitter.
Anyways Help please, I'm not sure what I did wrong it looks great, I took the glass off and pushed the ribbon buttons (using the black square adhesive that came with the ribbon - should I remove it - ) to stick them to the areas of the glass that would need the light. To make sure they were flush and had contact to the glass.
