Help S4 browser tap zooms instead of click
ngiac
Often when I click a link/button/etc on my browser I get a magnifying glass function instead of an actual click. It occurs more frequently on some websites than others, for example on this college radio site: wzbc.org when I try to hit "play" 90%+ of the time it does not play, only zooms in on the red button uselessly. I'm not triple-tapping, there's no difference I can tell in the way I'm tapping between a zoom and a click. I tried googling my problem and messing around with my accessibility settings but nothing has worked. I really want to turn this "functionality" off.
Please help
1.Go to Setting
2.Go to My Device tab
3.Open “Accessibility”
4.Find “Magnification Gestures” under the vision section and tap on it
5.Disable this feature from the top right of the page
Is Air Gestures on or off? If on, switch off and let me know how you get on
