s6 edge helped needed
makina
got a s6 edge model g925f
was stuck on a boot loop so flashed with odin and it failed
so switched the phone of but now it wont turn on and cant even get into download mode
or recovery mode phone is dead had it on charge for over 3 hours incase it was that
still no luck if anyone can help me then thanks
got it to turn on eventually flashed stock firmware but still stuck on bootloop
if any one knows how to help with that would be a good help to thanks !
tryed 3 diffrent stock firmwares
Can you get it into download mode yet?
I'd give Samsung's Smart Switch emergency recovery a try. It should be able to get the right firmware by your serial no.
From quatar .. sister stayed there for a while then moved to tunisia.. she got a software update that crashed then the phone was on a bootloop ..
Phone was in warrenty but not world wide they says she had to go bk to quatar to get the phone fixed lol
If the imei says Hong Kong, China and Mexico, I would try Mexico first since you might have trouble connecting to Google with the other firmware.
