Not sure if this is the issue, but go into your Settings, and under Accessibility ensure you don't have Notification Reminder turned on. If it is turned on, the default is that it will remind you every minute for every app reminder. You can either turn it completely off or just turn it off for all apps except the ones you want to persistently remind you.
