S7: Custom Shortcuts and Changing Edge Icons?
CJ_Trudge
Hi,
I was wondering if it's possible to change the icons for apps on the S7 Edge's edge screen. I recently downloaded Urmun icon pack and really like it but they don't change the icons on the edge screen.
Side note: On the Urmun icon pack is it possible to select or deselect certain icons? I noticed there are a few variations of the same type, can you change which one is selected?
Is it possible to create you're own action or shortcut? I like the idea of one-handed operation and would use it occasionally but I don't want it permanently on. A quick select option for it would be great but not sure if making one is possible.
Thanks!
