S7 edge android system battery drain
chaosbeck0
I recently updated to oreo on my at&t s7 edge my battery SOT is only 2 hours and it does not last a day android system seems to be the culprit for battery drain any suggestion?
GUYS I FOUND THE SOLUTION!
So i sum up all the problems regarding android system battery drain in s7 edge and after applying this settings i got my battery running normal again.solutions are as follows
1. Clear data from google services
2. Force stop chrome , facebook
3. Smart alert off
4. In oreo restrict background usage of android system
5. Check that your cell signal are not low
6. Wifi always turn on select never
7. Google backup off
I applied all those settings and in upcomming time i will check what was the give culprit
