Chriswfail
S7 edge roaming indicator off HELP.
So I rooted my verizon s7 edge and it didn't work. After factory reset it showed custom and an open lock on startup. After trying to root again and failing I factory reset and the custom and lock were gone and all is good but every time the lock screen is on it says roaming indicator off and if I look with advanced signal status it says carrier: roaming indicator off. Help me fix this please. If this is the wrong spot for this, I apologize
