S7 Edge not displaying GSM network type
My network is set to auto on LTE/3G/2G.
If i go Settings> About Device > Status > SIMCard Status i can see the mobile network typ : HSUPA.
Can i see somehow this info in home screen in right upper corner near icon showing GSM signal strentght ?
Thx for reply . Agree with you, but it does not
Because you're not connecter to mobile internet. It will only show up for that. Because if you're not on mobile internet, it won't matter if you're using 4G, 3G or Edge. Calls and SMS will still be received through GSM network because voice calls and sms does not need to go through 4G. In fact, voice calls DO NOT go through 4G unless you have a special Voice over LTE service. 4G/LTE is mainly for interner data.
