droidbillh
Installed the OtterBox Defender on my S7 Edge. No issues getting it installed. Power, volume buttons work with ease. Easy to access charging port.
My issue is screen sensitivity. It takes a hard press to type. Around the edge portion sometimes you can't type at all. I tried two apps to help with screen sensitivity and they did not work. Under 'Languages' I adjusted the pointer sensitivity to the maximum position and that did not work either.
Realky wanted this case to work. I'm ready to send the case back and get a refund.
Any suggestions?
Any suggestions?
