Frolin
Using the default Samsung Clock app for both Alarms and Timer uses, daily. With Alarms you can select what sound file to use. Not found how to change the sound file for the Timer. The default sound is barely noticeable when sitting at the desk, but not so much if across the room.
So where to change the sound file for the Clock Timer option?
Not the volume but the sound itself (and not by a crack).
thanks,
Frolin
thanks,
Frolin
