A Android Question Guest Sep 11, 2013 #1 I have a Samsung phone and there is no optionfore to turn on my flash. The flash worked just fine two months ago. Is there a way I can reinstall?
K kevincott Android Expert Sep 11, 2013 #2 Welcome to Android Forums. Flash memory will go bad if you do excessive writing or sub-par manufacturing. Buying cheap SDcards is a bad idea. Start by popping out your SDcard and use your PC to make sure your SDcard works.
