Samsung Admire (MetroPCS) Original "Vold.fstab" file ? Please Help
After Trying to swap my internal memory with my external memory ! I replaced my /system/etc vold.fstab file and forgot to back it up ! & Now My SD card won't work on my phone this problem has happened to many As I see but I have downloaded alot of stuff and try so many things in 8 hours :/ havent rested trying to find a solution and I have no warranty or anything
I need someone with the same phone as me to please send me the original
vold.fstab file from their phone so mines can work please or someone to give me a solution I tried to system factory it but wont give me the file
also the the vold.fstab I have right now says this when I open it with notepad ?
## Vold 2.0 Generic fstab
## - San Mehat (san@android.com)
## Regular device mount
## Format: dev_mount <label> <mount_point> <part> <sysfs_path1...>
## label - Label for the volume
## mount_point - Where the volume will be mounted
## part - Partition # (1 based), or 'auto' for first usable partition.
## <sysfs_path> - List of sysfs paths to source devices
# internal sdcard
mount_deep = 0
ums_path = /sys/devices/platform/musb_hdrc/gadget/lun0/file
asec = disable
discard = enable
mbr_policy = skip
dev_mount sdcard /mnt/sdcard 1 /devices/platform/mmci-omap-hs.1/mmc_host/mmc0
# externel sdcard
mount_deep = 1
ums_path = /sys/devices/platform/musb_hdrc/gadget/lun1/file
asec = enable
mbr_policy = overwrite
dev_mount sdcard1 /mnt/sdcard/external_sd auto /devices/platform/mmci-omap-hs.0/mmc_host/mmc1
#end line ## keep this line
Can someone help me and edit it for me or something
if anything my email is chikitinxx@gmail.com
Please some one help me and Thank you very much :)
Looks like Rush has you going in the proper direction,
Welcome to AF,we are glad to have you, hope you enjoy the site, :ciao:
