GST GridTech
Hi.
I have the Note 8 & received the free microSDXC evo plus 128gb SD card. Problem is, I can't seem to save what I want to it. I first, dropped it in my note8 & attempted to copy from my windows 10 laptop & I kept getting device not found after maybe copying 1 dir. so I then tried to put the new Sd in the microSD adapter. Still no luck. Then I tried copying from my S4 to my Note8. No luck. I tried formatting it on the Note8, which formats it but copying. No luck.
Samsung memory support suggested I do a clean with DiskPart which works but attempts to format returns device not found.
I've came across a posting that indicated I needed to dwld & install 'Note8 USB drivers' but can't seem to locate them anywhere.
This has been very frustrating for a free gift for buying the Note8 that I would expect to just insert and transfer to it at will until 119gb is full.  Very frustrating.
Any help or direction you can provide would be greatly appreciated....
