Okay, so I got my Samsung fascinate about 2 months ago, not even. and I hate it. in case you don't know, its the touch screen with the 4 touch buttons at the bottom.. and has no flash on the back, so its pretty old version. however! when I got it, it always used to freeze. for example. I have a song set as my ringtone. I got a phone call, and when I did, the home froze, stopping.me from answering it, and yet the song played all the way through instead of the usual 20 seconds. I had to take out the battery to fix it.another example.. I went to turn on thescreen using the button.on the side, yet no matter how many times I pressed it, it wouldn't turn on! even if I held it down. had to take the battery out for that one too. I took it to telus, and they said it needs upgraded. great. upgraded to 2.3. gingerbread and it still did it. the next step was factory data reset. The freezing still happens, yet not as much. also, WORST problem ever with the phone, every single time the charger is plugged in, I try to use the phone but the touch screen goes all crazy and starts zooming in and out and pressing random things and pulling down the notifications
