F
Faulty wifi
Guest
Hi, so i recently bought a galaxy tab s 8.4 second hand and turns out i got the raw end of the deal. The wifi does not work, tried to get it fixed but to no avail. So im wondering if there are any other options. For example is there any sort of plug in wifi receiver that i could buy that would work? Any kind of solution would be appreciated. Thanks lee
