what now
Here's a help that might help someone that I just spent some time trying to troubleshoot.
I was in my calendar function and I'm not even sure how I ended up in "Tasks" (part of the Calendar app). All I know is that I could NOT get out of it. I crawled thru all the settings of everything. I powered the device down, and that didn't help either.
Finally I kept trying to press hard on corners, and drag from the edges,.. ANYTHING that might be "hiding" that I couldn't see but would give me options. In the upper right corner, I pressed firmly and saw 3 little vertically aligned dots, with a little delay popup saying "more options". But I had to do that about 5+ times as I couldn't react fast enough before it disappeared. Kept after it, and finally the "more options" opened up and a couple of choices, and one of them was "Calendar". Since it was my Calendar app that I couldn't get to, because "Tasks" was primary, I selected "Calendar". Hooray!! My calendar came up and I closed it and then selected te Calendar from the app choices again.. and it went correctly into my Calendar app. I hope NEVER to find myself in the Tasks app part of the Calendar again!! I'll reach for a post-it note FIRST!! Hope this helps someone.
