Help Samsung Galaxy ace boot loop help!
Motorbike
I really need help with my samsung Galaxy ace. It's in a boot loop I've tried
-taking battery out
-clearing data and cache
-using Odin to put more firmware
Any help would be great
Hi,
Did not realise there were so many different versions of the Ace, you have to be careful which software you use as some software is not compatible across all versions and can cause major problems !!!!!!
Googled your version S5830v and found this link below which implies it can be treated the same as mine which is 5830i
Need help please galaxy ace 5830v - Pg. 2 | Samsung Galaxy Ace S5830, S5830i, Ace II | XDA Forums
have a read and decide for your self, other more knowledgeable people may wish to add their comments as I am only an enthusiastic amateur.
If you decide your Ace can take the same software as my Ace I fixed the same problem I had on my Ace by following the tutorial at this link
[TUTORIAL] Unbrick/Firmware restore | Flash … | Samsung Galaxy Ace S5830, S5830i, Ace II | XDA Forums
I suggest you read the post a number of times, watch the video a number of times then take the actions in the video one step at a time.
Good luck, let us know how you get on.
