I have a samsung galaxy ace 2.3.6 (the original firmware from samsung), it is rooted. And I want to install a custom ROM, so I need to install Clockwork mod first. So I installed clockwork mod 4, and after installing it, when I was already rebooting it, It gets stucked at the start up screen showing my phone model.
I do not know what went wrong, i followed the steps mentioned in the threads i found:
1. Download the file, ClockWorkModAce.zip
2. Copy the downloaded file, ClockWorkModAce, to (the root-directory of) your sd-card.
3. Power off your phone (using power button).
4. Boot up your galaxy ace to recovery mode (Press Home + Power Button).
5. Select Update Zip From SD-Card option.
6. Choose the file (named : ClockWorkModAce.zip) you downloaded earlier. (Note :- Use Home button to select).
7. After it finishes installing the zip file, reboot your device.
--now after installing it, I cant open my phone anymore.
(((( PLEASE HELP!!! i dont know what to do, im screwed.
so to enter download mode, i need to press volume down+power+home simultaneously? right? So another problem, i cant enter in that mode.
) sorry if im annoying, I just need help.
now im in download mode! but odin cant detect my phone still.. what to do please.
