Help samsung galaxy ace duos problem
i am using samsung galaxy ace duos for past two months.I installed some applciations like go launcher home screen, android assistant and start up manager.The phone restarts continuously after installing this applciations.what may be the problem?somebody help me
Infact I was also facing the same problem with my Ace Duos..I would suggest you to try uninstall previous installed applications, which is causing the problem..Also I know there is a chance tht you wont be able to get enough time to uninstall those, coz it may reboot ur phone frequently.. For that you can try connect to phone to a computer > go to the place where its installed..SD or phone and delete the newly applications manually and restart your phone..this should work, as myself resolved this issue the same way..
Thanks
Roj
I just bought a galaxy S7562 duos and I'm having the same problem.
it keeps restarting once an hour...
do you figure out what app causes the instability?
thanks
