Help Samsung Galaxy Ace locked out
Help please!!! My numpty 10 year old son changed his pattern on his phone so his mum would stop looking at it.... he's forgot it and now he's had too many pattern attempts.
How can we re-set this?
He remember his gmail account details either.
Hopefully thanks!!!!
Numpty Alex's dad :mad:
only option might be to do a factory reset
you could lose all datas but makes the phone usable again
see if you could recover his gmail userid and password.. it would do the trick else the only option is for you to flash the phone again.
We are having the same problem, can't log in on phone through email though. I can log in to Gmail on my computer but phone keeps saying invalid username or password. I am getting the runaround from samsung and retailer. I don't know what to try next any ideas?
thanks cassie:confused:
I had the same problem but whn it asks if I forgot my pattern "code". Then I just typed my Gmail account and its password and I had to make a new pattern "code".
oh sorry, I didnt noticed that she doesnt remember his gmail accounts. Well cant help u with that problem.
I just searched the internet and some guy had the same problem with his SGS2 and this was the answer "Yes there is another way however you will have to
perform a factory reset of the device. This is the only way to
gain access to the phone again. If you have a Google account
synced to your device, your contacts, calendar, etc. will be re-
synced to the device after you run the initial setup again. any
data that is stored on the SD Card will not be erased. All of the
apps you have paid for can be put back after you reset the
device by opening the Market, pressing Menu on the phone and
choosing "My Apps"."
