Help SAMSUNG GALAXY ACE UPGRADE PROBLEM 2.3.4 to 2.3.6
shafi1
Hi all,:)
I have Samsung Galaxy Ace - Gingerbread-2.3.4.
I am trying to upgrade it to 2.3.6. My Kies is the latest. It shows the "Upgrade Firmware". My carrier is "TML". But when i proceed, while downloading firmware; after 1 or 2% it shows "Unknown error ocurred".
My phone was rooted , I unrooted it through unroot.zip. There are 3GB space in my C Drive. I am stucked for 3 days.:confused:
Please someone help me. Can anybody provide me the link of that carrier.
And also the tips to do.:rolleyes:
Were you trying to upgrade while the phone was still rooted??
Well i don't have any link to TML firmware(didn't you make any backup ever before?), but for the meanwhile i would suggest that you flash a fresh samsung stock firmware through Odin to get things running again until you can find a TML firmware.
As my personal opinion: Stay Away From Kies, its a bigger trouble than an aid.
Thank you for your advice. I have already upgraded it through Odin.
But i had the problem of "Data network mode" in 2.3.4 . It is not yet solved "Use packet data" remain checked but the sign is not coming at the top.
Somebody please help me. I cannot use internet...................
First check your APN settings, if thats fine then i would suggest you use a 3rd party app to enable packet data, its a guess but its worth trying. Use something like widgetsoid or any app that enables/disables packet data connection.
