Help Samsung Galaxy Mini - Bricked - Help
I have a Samsung Galazy Mini and i tried upgrading the firmware using Samsung Kies.
Something went wrong and now its bricked.
(By something i mean Kies kept giving me errors, and got sick of it and "tripped" over the usb cable pulling it out of my phone while i had the construction worker, with downloading underneath, on the screen)
Not detected by the PC, phone wont turn on, hard reset buttons wont work.
Phone was not rooted and odin was not used.
Help! Anything helpful would be appreciated, thanks!
try this;
remove battery,press vol up+vol dwn+home +power buttons, & insert battery whilst pressing buttons, should bring you into emergency d/load mode, then flash firmware
if you have no response at all then it is possibly a hardware issue, caused when cable got yanked, try samsung service centre, sorry i cant help.
