when i enable handwriting on my s planner and write something it shows up. but then when i disable the handwriting mode what i drew/wrote does away. is there a way to fix this?
Welcome to Android Forums! I will try and help as best I can.
I have a Note 10.1 and went into s-planner, but I was unable to duplicate your problem. I think we need a little more information about your setup and the exact way you get the failure.
Info we need:
Are you using the default Samsung keyboard, or a third-party?
What is the exact sequence of events? What buttons do you tap on and in what sequence.
This could help us re-create the problem. To get us the info, there are two avenues: You can re-submit your question with the additional info the same way you submitted this one, or you can join the forums for a better back and forth exchange of info.
