This morning I went to use my phone and as soon as I pressed a button it automatically switched itself off, and then on again but wouldn't go past the load screen. It stayed on the load screen for about 5 minutes which isn't the usual time so I switched it off and it automatically turned itself on again and done the same thing so I then took the battery out and once again it repeated itself. I then tried to reboot the whole phone which didn't seem to work as it still done the same thing? Thinking it might be that it needed charged I plugged my charger in to which it showed the symbol that meant the charger was connected but wasn't actually charging itself. So I then tried to turn the phone on to which it had completely stopped working wouldn't even turn on at all? Bought a new battery and that wasn't the problem either? does anyone have any suggestions as to what might be wrong with my phone?
Thanks for any help
Kirriejim
Thanks for any help
Kirriejim
