aieie
Hi,
I left my phone turned on and under charge overnight, and found it off in the morning with the battery at 95%, so not fully charged !?!?
Upon pressing the power button, the Samsung Galaxy on5 logo shows up, then it makes it to the next logo, SAMSUNG, but it remains stuck there. Sometimes it reaches the next logo, the one of the carrier (T-Mobile).
I googled and tried whatever I found recommended. Holding the three buttons volume-up, menu and power together I can access the Android Recovery screen. Upon trying to “wipe cache partition” I get a bunch of errors/warnings, like
E:failed to mount /cache (Invalid argument)
E:can’t mount /cache/recovery/last_local
etc etc
I also attempted to “wipe data/factory reset” without success, but again a lot of errors, and nothing happens.
If I press together volume-down and power buttons, it says “Downloading - Do not turn off target”, but it does not go anywhere.
Note I once left the phone on on the carrier logo screen until the battery got empty, and then re-charged. I could get the battery to 100%. So I have no clue what is going on. The screen works, the battery works and recharges, is it a software issue? Can anyone suggest what to do next? Thanks in advance for your time!
etc etc
