TheLebowski
I just purchased the Samsung Galaxy 3.6 player and am having trouble with the wifi connectivity portion.
The player is able to recognize my wifi network, and after entering the password for the network, it says that it is connected.
Even though it says that the device is connected to the network, I am still unable to access any of the internet based features, such as the web browser, app marketplace, google mail, and even the software updates.
This is what the error message reads when I attempt to wirelessy update the software.
"failed to update firmware due to network or server problem."
I have also tried to update it via PC kies but it says that no updates are available.
I think this is likely a problem with my wireless router but I am not sure how to diagnose it.
If anybody has had this problem, or a similar problem, and could point me in the right direction, i would greatly appreciate it.
Here is some more information on the device in case it helps.
Model Number
YP-GS1
Android Version
2.3.6
Kernel Version
2.6.35.7-cl964210
se.infra@SEP-76#1
Build Number
GINGERBREAD.UEL85
EDIT:
also, I'm not sure if it means anything, but we have a ps3, xbox 360, and Ipad hooked up to the same router, all of which work flawlessly.
Model Number
YP-GS1
Android Version
2.3.6
Kernel Version
2.6.35.7-cl964210
se.infra@SEP-76#1
Build Number
GINGERBREAD.UEL85
EDIT:
