Root Samsung Galaxy Proclaim: Non supported battery after root... Fix?
i've searched and searched, but come up with nothing.
So today I decided I'd root my phone. After that was all said and done, I started up the phone and got a message, "unable to charge non supported battery see user manual." I never had any problems with this new battery, an Acesoft 2050 mAh that I've had for about a 1.5 months. I bought this battery because my old Samsung battery got fried. (I took it out and dropped it into water...)
I just purchased a Samsung battery off of amazon for $10, hoping that it'll come and fix all this.
I wanted better battery life, a faster phone, etc... None of that is useful if I can't charge my battery.
I used this root guide:
theunlockr (dot) com/2012/12/29/how-to-root-the-samsung-galaxy-proclaim/
(I'm new, I can't post links yet. I'm sure you know what to do to go to the webpage)
So, my question: How do I fix this "non supported battery" mishap? Is there a different root or kernal I have to use? Will the Samsung battery I ordered fix this?
Thanks!
EDIT: Is there a way to possibly bypass the battery check? I'd really love to be able to use my phone sometime. Somebody has to know...
This happened to me with the Samsung Admire, I bought an original samsung battery...same exact one and I get that dumb message. There shiuld be a way to manipulate the system files. It seems samsung chips there batteries
Had the same issue with my old one. Sent it back and got the centura as a replacement. Using the Ultimate 2 now.
