I am in Canada on Bell and I have a Samsung Galaxy S. Yesterday I noticed my phone was extremely hot and noticed my battery was nearly dead, but I had ZERO applications running. I plugged it in and it charged a lot slower than normal, but everything still works properly. I did notice that my data indicator is always showing that it's sending and receiving data (red and green arrows) where as before yesterday it would be grey unless it was syincing or I was using data myself. It's sucking through my battery life at an alarming rate...~5% per 10 minutes when it is idle with nothing running and the screen off.
I have tried turning off the background data, syncing, etc... and nothing has helped. I did not download anything yesterday so there are not any new programs causing this. The only thing I did yesterday is I had a video running on the phone for a long time but my screen is set at the lowest brightness and it appeared normal when I was done the video and closed the application.
I am now running the battery to completely dead then recharging it while off to see if that helps, but I truly believe it has to do with the data indicator. What could cause data to be constantly running if I have both sync and background data off...
My battery usage is also at nothing with only the display and cell standby...period (94 and 5% respectively).
Suggestions please.
Suggestions please.
