Hi there,
I have two Wifi Access Points (APs) at home, both using the same SSID, but on different channels.
I expected the SGS to automatically move (handover) from one AP to another based on signal strengths that vary depending on where I am.
However, this does not happen. It stays on the AP that it is connected to, even when moving to very poor signal levels.
I need to manually trigger this (e.g by disconnecting from the AP).
Is there a way to fix this? e.g. configuration or Android app.
By the way, I also tried configuring the APs with different SSIDs, but this didn't work either.
Thanks
Tim
Thanks
Tim
