Help Samsung galaxy s white no entry sign
lolpop
what is the white no entry sign on the samsung galaxy s mean ? the sign is beside the clock. how to remove the sign ?
The white no-entry sign means " No Signal ". Check your SIM card is fitted ( correctly ). It may be because you are in a no signal area.
Ray
no entry sign on galaxy2 next to battry charge appeared recntly why?
As explained above, it means you have lost your signal to the network. This could be a fault with the network, you're in an area with poor/no reception or the SIM is faulty/loose. Try taking the battery out while the phone is switched ON then check the SIM while you have access to it. Give it a wipe to remove any dust that may have accumulated on the SIM and blow out any dust from the SIM holder on the phone.
Ray.
