Help Samsung Galaxy S5 SM-G900R6 5.0 Lollipop (Firmware Version : G900R6WWU2BOB3)
Manoj210891
42
24
Pre Requisites:
Before proceeding to update. we recommend to backup all your device data and settings to restore later when you need that. However, official firmware restore all previous data but if your device get stuck at bootloop issue or fall into any error, the backup file will help you to restore all your data.
  1. Check your device battery percentage, make sure that your device have at least 60% battery power
  2. Backup all your device data and settings to external storage
  3. Check that USB Debugging is Enabled on your device, otherwise it is not possible to connect and transfer files between PC and Galaxy S5 via USB
  4. Install USB Driver for Galaxy S5 on your PC
How to Flash
Step 1:-Download and extract the firmware on your computer.
Step 2:-Open the Odin and load the Scatter / Binary File from the Folder.
Step 3:-Connect your Smartphone to computer using the USB Cable.
Step 4:-Click on Upgrade Odin to Begin the Flashing.
Step 5:- Green Ring Will appear at the end of successful Flash.
NOTE:- Disable AdBlock. If Adblock Enable Link not work.
Warning:- *Flashing Stock Rom is always a data loss procedure.So, always take backup of your personal data before Flashing the Stock Rom.
BEST TECH IN 2023
Smartphones
