A
Android Question
Guest
I am currently puzzled on which of these two android devices to buy, what are your thoughts on which to buy?
I'm not really sure, I used an S5 and it was pretty big.Do you want a really large phone or not? For me the size difference is such a big factor that that would settle it, one way or another.
The S6 is the same size as the S5, but the Nexus 6 is an inch larger. I would try them out in the store for awhile and see which one you like more.
S6: 143.4 x 70.5 x 6.8 mm (5.65 x 2.78 x 0.27 in)
N6: 159.3 x 83 x 10.1 mm (6.27 x 3.27 x 0.40 in)
Ask Kate says, look at both, hold both, and see what you think.
