Samsung galaxy SW Rev check fail device 6 , binary 5
That 'binary 5' error often means that's not the correct ROM for your device, or perhaps the ROM became corrupted during the download process. Where did you obtain it and are you sure it's the correct ROM for you particular model? ROMs are not interchangeable so it's important to be very selective. Be sure to get the ROM that exactly matches your model I.D. and your carrier. Do not mix-and-match -- i.e. if your phone is a SM-925F do not use the firmware for a SM-925C.
Try going here
https://www.sammobile.com/firmwares/
or
https://updato.com/firmware-archive-select-model/
to find the appropriate stock Samsung ROM.
