Help Samsung Mesmerize Problems
trewyn15
Hey guys, i'm hoping your guys can help me with this, I have been having trouble with my mesmerize and I went to US Cellular but of course they were no help. Lately, my phone will charge sometimes, but when it does, after about an hour it likes to say it's charged about half way or 1/4 the way. And sometimes after it's unplugged it will continue to say it's charging all day. Lastly, I can't connect the phone to my computer anymore, it worked one time and the computer noticed it but then immediately said it was gone.
The US Cellular people told me there was corrosion in the connection, cleaned it out, told me it would just get bad again and good luck hopefully I had insurance. Then I went back to someone who had a brain and he tried to reset the settings to see if it was that, and it wasn't. But I didnt have my ID so he couldnt help me any further.
What do you guys think the problem is? I think there's something wrong with the connection in the phone itself. But I'm not on the premium belief program so i can't get it replaced for free. Oh and I got the phone on the 24th of December, so I think it could also be a manufacturer part error. But I don't wanna sit and wait for US Cellulars replacement plan to take half a year again.
Any help would be great, thanks.
It sounds like a defective phone. I would return it for replacement under warranty. Corrosion in the USB? That's either something you did (i.e. getting it wet) or something that happened before you got it. Metal doesn't corrode by itself.
Please help me, i powered off my mesmerize and went to turn it on and it will start then pause on the galxy s screenpart. I am staring at that S for twent minutes and my phone hasnt turned on. I even tried taking out the battery and retrying what should i do?
Try taking your battery out which will turn it off and place it back in hold the poser button down till the G S comes back on, I know it does suck when it hard boots it is so slow to boot if I don't turn it off from the menu ofter hitting the power button.
my twlauncher isnt the same,
jus got a mesmerize phone And started downloading different apps,when I went back to the home screen at the bottom of my phone where it showed phone, contacts, messaging,and applications now only shows messaging and applications
What happen I would like for it to go back to normal:confused: I tried diff launchers,but dnt like them
Answered in your thread...If you need help you only have to ask once. We promise we can see the one thread.
