A
Android Question
Guest
Carrier: U.S. Cellular
Samsung Mesmerize
Galaxy S
Okay so today I had to go to a meeting and my phone was working absolutely great. I cold use all my soft keys (The four bottom touchscreen buttons) appropriately and they were working just fine. I shut my phone off for the meeting. After that, I turned my phone back on and I noticed that the soft keys on the bottom didn't light up like they usually do. After the phone was on, I tried to see if any of the soft keys were working, and they weren't. I then shut my phone off, and (stupidly) held the power and the volume keys at the same time, turning my phone to the reboot screen. I then realized you have to press the volume keys to change the selection and press the back button to select it. As I said, my soft keys don't work at all so I can't select anything so now it's stuck like that. Is there any way to get off the reboot screen? Or change the soft keys? Like, switch them to new ones? I really need help! I've tried everything! Thank you!!![Smile :) :)](/styles/smilies/google/smilie.png)
Samsung Mesmerize
Galaxy S
