samsung mobile core battery charger plugged not charging
  • Start date Start date
A
Android Question
Guest
samsung mobile core 18262 charger plugged but not charging please solve this problem and continuously hanging not run smoothly
Hi,
For your charging battery problem ill suggest you to try the following one by one till you solve your problem:
1- Try a new or different charger.
2- Clean your Device USB port.
3- Try a new or different battery.
If none of the above worked, then i would say your USB port is damage and needs repair.
