Samsung note 10.1
  • Start date Start date
A
Android Question
Guest
How can I transfer the files from use/hard disc to my device...?
Welcome to the forums!
If your Galaxy Note 10.1 has 4.0 or later software, it is capable of accessing USB drives through a USB cable. This will require a cable that plugs into your charger port and also accepts standard USB drives. If you have this cable, you should then be able to plug it in and access the files using a file manager, such as ES Explorer.
Hope that helps!
