Any note that was deleted stays in the recycle bin for 15 days so that you can undelete it. If it's not there did you have the note app set to sync to your Samsung account? If so go into the app settings and select import and choose your Samsung account and see it is retrieved.
We are talking about the same app right? If so are you on the latest version?
Personally never used the app before so not sure when the recycle bin appeared, but maybe you have an older version that does not have this feature.
Did you setup sync option?
