Samsung Problem
Installing System Update - With Blue Screen and then It shows:
No Support SINGLE-SKU
Supported API: 3
E:failed to mount /efs (Invalid argument)
dm-verity error...
E:failed to mount /cache (Invalid argument)
E:Can't mount /cache/recovery/last_kernel_manual
E:Can't open /cache/recovery/last_kernel_manual
E:failed to mount /system (Invalid argument)
E:Can't mount /cache/recovery/last_locale
answer me, what do I do?
Phone is constantly showing me only these logs. and It doesnt get switched off. Een if I try to switch it off. It won't.
If you press home + power and hold them both you can force a shutdown (simulated battery pull). To recover You will probably have to use Smart Switch
