Samsung S10: Can one create a shortcut to the camera which starts it in Pro mode?
peterh337
This is possible on my S7. You set up the required config and there is a menu option to create a shortcut.
Basically I need to shoot RAW every time I start the camera, without selecting Pro mode manually.
Many thanks for any tips.
Hi there, not sure if this answers your query but if you go into camera setting and select camera modes, there is an option to keep using the last mode. If you select this then select Pro and Raw in the save options setting would this d o what you wanted.
That's great to know; many thanks.
On the S7, there was no way to save the Pro mode, but you could set it and then create a desktop shortcut which came up with that mode (plus whatever other config you set up).
