Hi welcome to Android Forums. Sorry it's taken so long to get back to you.
Connect the USB/Charger cable that came with your phone to your Macbook Pro. Drag the notification menu from the top down. You should see the USB symbol, press that. It will give you the option for Mass Media. Run that and turn it on. You should be able to find your phone as an external hard drive on your Mac from there.
