countryblue
Member
This is a strange problem. An example would be of a contact that I had to edit to add a *82 prefix. I actually have several versions of the contact with different titles.
When I ask the Google Assistant to call the number, it shows me list of the related contacts, in order to select one of them, but when the call is generated, the non-prefixed number is used.
Previously, after editing the contacts, if I went back to a couple of them, and tapped on them, to display the phone number and "History" and "Storage Information. The original phone number, without *82, was still listed there down below the current version of the number, but when I chose "edit", that non-prefixed number was nowhere to be found. I deleted and remade all the related contacts.
However, now, when I repeat the sequence with Google Assistant, and choose the preferred contact, it still dials the number without the prefix.
Is it the cloud, or some stored memory on the phone that this number is being retrieved from? Is there a way to fix this?
