Hi there,
I have a Samsung Galaxy S4 GT-I9505 and the other night it got really hot for some reason and when i finally noticed it the screen was frozen. I removed the battery and let it cool down. But now when i replace the battery and turn it on, it will get to the boot screen and then usually freeze or reboot again. The screen looks ok but occasionally some colours will flicker before freezing. Ive played around with it a bit and i notice if i apply a little pressure like bending the phone i can get it to boot all the way so that i can view messages etc. But it will only last less than a minute before freezing. I tried a friends battery and it had no change so im wondering if the motherboard overheated and is stuffed?
I have another friend who has a s4 GT-I9500 that has a cracked screen. I was wondering if i can swap the motherboard out of hers and put it into mine? And if so can i retain my data,or is it impossible to swap the memory storage out of mine into hers? Id love to get my phone running again so any help on this would be much appreciated!
