Hi, I have an AT&T S6 Edge + (SM-910A) and it is unlocked and am using it on T Mobile.
Can I flash either the T Mobile software or Stock Samsung software, wouldn't mind either option.
Thank you in advance for any replies.
A better option (for AT&T Devices) would be to use the app Package Disabler Pro & de-bloat via disabling the offending apps (DO NOT UNINSTALL,DISABLE ONLY,serves the same purpose,but,totally reversible,in the event you need warranty service/accept future updates/etc......)
