A
Android Question
Guest
My Samsung Galaxy Tab 7.0 has decided to stop charging/boot. When I plug it into the charger it shows the battery symbol intermittently. If I plug it into my PC it triggers the device plug-in and unplug sound on the PC as if the PC is connecting/disconnecting from the device in a loop. It will keep making these connect/disconnect sounds on the PC until I unplug the tablet.
Has the device failed? Can it be just a bad connection cable?
