SmallShinyAnt
Hi All
I've been struggling with the default network settings on a Samsung tablet device as i guess im trying that it not obvious. I am trying to use it with wifi and Ethernet at the same time. The static address is for use from an internal network where i will be using somethign like VNC to connect to it, the WiFi connecting is to be dynamic so it can connect to wireless networks for remote demonstration.
I don't(often can't) use the same connection for internet and the remote connection as the tested internet connections can be slow or intermittent and i need to be able to switch between access points. This is a pretty standard config on desktop OS's, but i'm starting to think it's not possible on android, so checking to see if anyone has worked around this before?
Wifi : DHCP
Ethernet: Static with no gateway i.e. 192.168.1.101/24, GW: Blank DNS: Blank
Two issues im having so far, first is that when i connect ethernet it seems to disable wifi, and the second is that it wil not let me create and static address without adding a gateway
Galaxy Tab A7 (Android 11).
Wifi : DHCP
