TarekElsakka
Hey there
Yesterday I installed Go Launcher and a couple more Go applications, widgets, and tweaks. I also created folders and put applications inside them and everything.
The problem is that my phone significantly slowed down ever since I did so and I feel like the battery is getting drained rather quickly also, so I decided I want to remove all the Go applications and go back to the default HTC Sense launcher because it felt snappier and quicker.
I'd like to save all the settings I've done, though, at least just the Go Launcher settings (folders and icon locations on the home screen pages), if that's possible, in case I want to reinstall it at any time. I worked so hard on it and put a lot of time and effort so I don't want it all to go to waste. I have an application called Home Switcher which allows me to switch between Launchers but then again I feel like it won't actually do anything as Go is still installed.
Is there anyway around that?
And by the way, is there an application that lets you create folders and add applications inside them (not on the home screen itself - the one that appears when you unlock the phone - but rather on the pages that appear when you tap the Menu button), if you know what I mean.
Thanks guys, I appreciate it.
