Scheduling White Noise
mk2019
Hi all, I would like to play white noise sounds for my son starting at his bed time, and ending when he normally wakes up. I would like it to happen automatically, on a schedule. Does anyone know of an app with this functionality, or have an idea of how to do this? Thank you.
A lot of multimedia player apps already include a repeat feature. It will be shown as 'loop' or 'repeat' -- as a couple of examples, with the MX Player Pro app as you're listening to an audio file that option with be shown as loop if you tap on the three-dot contextual menu in the upper right; with the VLC app when you're listening to a file the repeat feature has its own icon in the lower left, two arrows in a rotating shape. Tap on it one to repeat once, or tap again to look until you manually stop it.
Don't forget to minimize the app so just the audio is playing and the screen goes into sleep mode, and don't forget to keep that phone plugged into its power adapter.
This is something I happen to download, when I was away on one summer trip, I download a White Noise level app, since I have tinnitus (ringing in the ear) that is fairly frequent. I sleep mostly with my air purifyer on, but I did had my phone on the white noise, it was still on this phone, I am using so approx. three summers agoish, it was one of my many first timer apps. It did select different fans and fan settings... It is free for google play :)
