screen blinking and auto reboot !
  • Thread starter Thread starter mileftozkewl
  • Start date Start date
M
mileftozkewl
Guest
i bought note 2 less than 2 months ago , from the 3rd day i started noticing that my phone automatically reboots mostly while i am on a call and i also noticed that it's screen keep on blinking randomly in every 10 minutes (or less than that and sometimes no blinking at all) sometimes it's screen get on automatically. i performed factory reset and two days back i also took the phone to the service center, they just re installed the same software but i am still facing the screen blinking problem though my phone has not rebooted since then. someone suggested that it could be due to faulty battery , i took a closer look at the battery it fits well and no sign of swelling kindly help me
Not all battery faults are visible. You could try a replacement battery. If that doesn't solve it, I'd take it back to the service centre, show them the problem and tell them that this is what they failed to fix last time.
Or you could try that first, and see whether it saves you buying another battery :)
