shovenose
I needed a secondary phone for my business and after two fails of "new" HTC One M8s on eBay (I figured it would go well with my primary phone, an HTC 10) I decided to try Samsung. Got me a new in box Samsung Galaxy S5.
Unfortunately, there are already a few things I hate, and the phone does feel really plasticky and cheap. I guess that's why I don't really like Samsung phones. All that said, my biggest two issues that I'm hoping to find a solution for:
Screen ghosting: After just one night of use (well, one night of installing about half a dozen updates in the process from 4.4.2 to 6.0.1) there's already some ghosting in the screen. It's not that annoying, it's just weird on a brand new phone - what can I do to keep it at bay, or is this normal and it won't get worse?
Rear battery cover warning: I've seen the message to make sure the battery cover is tight many times. But it's definitely fastened on there securely, and in a case... I did some research online and this message does not have a sensor, it simply shows up. Any way to disable it?
I absolutely don't want to flash Cyanogen or anything else like that... I must keep the stock T-Mobile ROM to ensure functionality of WiFi calling.
Thank you for any advance.
